NAV voice
NAV voice
OK....I'm sure this is something simple, but I can't for the life of me get the "voice navigation" to turn off. I've tried turning it off in the setup menu with no luck, no matter how I try to set it up. I've also tried to turni it off with the console "voice" button....still no luck.
What am I doing wrong?
Press enter while in regular guidence (not while the turn display is up) and select guidence off. If you want to have guidence but not sound then do the same thing accept set volume to zero.
That said has anybody noticed the difference in voice volume between autopilot on and off. With autopilot ON and volume at 1 the voice is almost two loud. With autopilot OFF I have to raise the volume up to 3 or more. Also with autopilot ON and stereo volume at zero (turned all the way down) the voice is just as loud. None of this is a problem just odd how it works.
I have noticed some strange things with the nav voice.
Has anyone experienced the following?
1. nav voice volume is loudest in left, front ,driver speaker
2. the female voice sounds a little staticky especially when pronouncing words like "starting ..." (beginning with s)
3. The nav voice can not be heard very well when the stereo volume is very loud (>17). Even with the nav volume set to 3 or 4
I would think that the audio pilot would decrease the stereo volume enough to allow the nav voice to be clear -- Not the case
This bugs me the most!
2. Are you making fun of the woman's speach impediment? ;-)
3. Nav voice isn't loud enough to overcome the sound of the stereo from medium to loud volumes.
ss s sss sorry. I should be more considerate ;-)
Thanks for the reply. I guess the Audio pilot isn't perfect. You would think it would have better sound adjustment.
Enough complaining on my part. The car is great!
2. Have not noticed any problems. Maybe your disc needs to be cleaned. If possible maybe you can record it and let us download a sample. If its that different maybe you can get a new disc from Mazda.
3. If you have autopilot on the the sound is amplified. You can place the radio volume at zero (turned all the way down, haven't tried mute) and it will be just a loud. If you have the volume turned up the autopilot should compensate. With autopilot off you have to crank the volume up to be heard. I will try later with stereo volume up to 17 and see what I can hear.
Go baby!
on
I've noticed #3, regardless of volume setting on stereo, nav, or use of Autopilot. Nothing seems to fix it.
Haven't noticed 1 & 2.
edit I've noticed #1 now, too. Just wasn't listening for it before.
This is a good idea. I'll check the nav disc for any obvioius dirt/defect. I'll see if I can get a recording.
This is probably me just being ****.
Thanks for the confirmation about the nav sound coming from the left speaker. Just wanted to make sure.
ShellDude
10-01-2015 09:55 PM
